DIY Struts Replacement
  #11
Old 02-12-2010, 08:45 PM
Bunklash's Avatar
Thanks DF. Tire pressures are even all around. My left front tire does show more wear around the outer edge. I'm going to swap back and front tires to see what that does, then probably two new tires on the front with an alignment. I appreciate the help.
Old 04-05-2010, 07:08 PM
mwtalent's Avatar
Default Trailing Arm and Sway Bars
I'm replacing the left rear strut, trailing arm and sway bars. Had a little argument with a tree Do you know the size of the bolts so I can buy a socket that fits it?
Old 04-19-2014, 10:59 AM
Elle's Avatar
The rubber "tops" of my friend's 2002 Elantra front struts are cracked. In the drawing below, is it part 54610 or 54620, or both, that she needs?
The drawing is also visible at http://www.jimellishyundaiparts.com/...ssembly=414853
Old 04-20-2014, 12:58 PM
Neither. They are just dust covers and not listed in that diagram.
CamronTheGreat
05-07-2010 09:31 PM
frodo19v
10-14-2009 02:09 PM
WillPartHyundai
08-03-2009 02:36 PM
mikibark
08-14-2007 07:53 AM
jweidler
04-30-2007 01:51 AM
Quick Reply: DIY Struts Replacement
