Slow Fuel Fill Problem Diagnosis
#61
No Blow Up: no worries
So the question was will this cause damage to the car or blow up etc. Answer: NO.
It is illegal in the US. But the chances of getting caught are minimal. BUT it might cause the check engine light to come on and we here at the forum would like to know, so please keep us informed. WHY: If you do a little reading on the emissions system you'll find there is a fairly elaborate system to check if everything in the fuel vapor recovery system is all in good working order. By removing the charcoal you may change the airflow resistance in the system just enough to cause the system's self test procedure to throw a fault thus causing the check engine light to come on. If that happens and you use similar repair techniques as used in resolving the charcoal problem I expect you will disable the check engine light. Thus I expect you will ask how to do that in your next post so let me just go ahead and answer that now. The fastest way is to drill a small hole through the dash display and into the check engine light until it goes out. The small hole will not be very visible and not to worry as the vapor from the charcoal canister will not come out of the hole and even if it did the check engine light won't come on. Good luck. /s. BTW if it were me I'd replace the canister even though it costs a bit. But that's just me.
#62
Thanks!
#64
Yes my wife's elantra has the same problem
I noticed my '05 XG350 doing this when I filled up this weekend. Very frustrating! One thing to add that is sort of related. Isn't there supposed to be a small, round, spring loaded door just where you put the fuel nozzle? Mine has disappeared. Has this happened to anyone else?
#66
#70
Petrol Problems
I got under the car today at around 10:00 and crawled out at about 16:00 .
Took the Charcoal Canister, fuel line assembly from filler port to petrol tank out, cleaned all the pesky charcoal chips from the lines was tempted to drop the fuel tank but thought better of it..
Refitted it all back together with a new $160 Canister took it to the garage and filled her up.
And it worked by heck.
It was only 86F in SW Florida today so not too hot.
