Radio & Clock not working in 2002
Old 01-13-2013, 05:17 PM
Keith Grauman's Avatar
Default Room LP fuse
While charging my battery using jumper cables, had wrong jumpers polarity connected, then after proper connection, there was no light, no radio, no central locking..and the room lp fuse keeps blowing every time i put a new fuse in.
  #22
Old 01-15-2013, 05:32 PM
kirko's Avatar
Did you check the fuses a second time when you replaced it. If it is blown again then its off to the Auto electrician as you may have fried a wire,
regards
Kirko
  #23
Old 08-09-2014, 01:00 PM
Spike451's Avatar
I did the same thing by mistake and now fuse #25 keeps blowing on me? Any suggestions where I can look? Did I blow the ETACS unit up? Any suggestions would be greatly appreciated! 2006 Hyundai Elantra 4 door
  #24
Old 01-09-2017, 04:38 PM
johnnykzoo's Avatar
I have a similar problem. crossed the wires for a second while jumping the wifes car in the dark. replaced the 15 amp LP fuse (it was blown) and it immediately failed.
  #25
Old 08-11-2018, 08:55 AM
Earl Greer's Avatar
Originally Posted by Doohickie
This is easily the most common electricalissue with Elantras when the stereo is messed with. Fuse 25 powers a lot of things, including radio memory, the clock, dome lights, and the ETACS which controls the alarm system. There is a second source of power to the ETACS that comes on when the key is on, that's why it works when the engine is running.
ROOM/LP means "Room Lamp"(dome light). I guess they label it that because they feel someone will notice if their dome light goes out and they will then know what fuse to check.
I added an extra light in my trunk and I think the wire rubbed up against the body once, shorting the power and blowing the fuse... I was in a curve and had a bag of cement back there. It went thump against the side and then my radio died. I replaced Fuse 25 (with a spare from the fuse box) and was on my way with everything working again. It freaked me out pretty good at the time. So while a lot of the advice I give on this board is from reading the manuals and stuff, this one I actually have personal experience with.
#25 fuse keep blowing out what now
  #26
Old 08-11-2018, 09:51 AM
avisitor's Avatar
Disconnect the radio and then try replacing fuse
Many times the radio blows or burns out ... short
  #27
Old 07-18-2020, 08:26 PM
Russell Lynn Vargas's Avatar
If the radio, and the clock, and oh, say the door courtesy lamps, the trunk lamp, the dome lamp are all out, check Fuse 25 in the Passenger Compartment Fuse Box, the one at the right end of the bottom row:
I know you said you checked the fuses, but that's the one that controls all the stuff I listed. If it's not that, and those lights and stuff work, you may have a problem with your ETACS, the unit that controls your alarm and a lot of other functions in the car.
I replaced the radio in mine all my lights work everything qork but my clock and my alarm what would that be?
  #28
Old 07-19-2020, 07:12 PM
avisitor's Avatar
Check all your fuses (engine bay and cabin)
Robert156801
06-10-2019 07:04 AM
Carlos Castillo
02-22-2017 08:18 AM
Tinindian
08-26-2014 08:03 AM
DrivingComprehension
03-17-2014 11:13 AM
lladybug01
05-15-2009 10:28 PM
Quick Reply: Radio & Clock not working in 2002
